Filing down piston rings for cooling?
Old May 17, 2006 | 07:30 PM
R4][N_M4l{3R's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 383 Stroker
Axle/Gears: 7 1/2 Inch 3.23
How does this work exactly? How effective is it?
Old May 17, 2006 | 07:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Filing the piston rings to make the engine run cooler?
Old May 17, 2006 | 08:00 PM
Engine: 383 Stroker
Yeah someone told me about it today. I was just wondering how it works.
Old May 17, 2006 | 08:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It doesn't.
Old May 19, 2006 | 09:40 PM
evil_dave's Avatar
Car: '89 Trans Am
Engine: LO3
Transmission: 700-R4
Now, its been a while since automotive class, so someone can correct me if I'm wrong on any of this.
If you file the piston rings, you will have too much blow by. This is when the exhaust gases go into the crankcase. All engines have some blowby, but too much is not good. I'm sorry that I don't remember the exact reason for that - I know a portion of it is you will have no compression. The fuel/air mix will escape into your crack case also, and maybe some oil will come up (not sure on that part)
Also, if I remember correctly the piston rings clean the excess oil off of the cylinder walls. They have nothing to do with cooling... Other then I guess your engine would be a lot cooler when it stops running!
Thats pretty much the basics as I remember, but as I said... Its been a while, so feel free to correct me.
Old May 20, 2006 | 08:19 AM
Engine: 383 Stroker
It didn't make any sense to me, thats why I posted up. Thanks.
Old May 20, 2006 | 11:55 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
filing rings
You file rings to fit the cylinder. You do each ring one at a time to its designated cylinder to the manufacturers specifications. This relates to cooling in only one way I can think of and that is compression makes heat. The higher compression you have the more heat you have. If your rings are filed too much or are worn and not sealing very good you get blow by which means you are losing compression and your motor cant make as much power as it should.
MitcherNeaf
Sep 24, 2015 09:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
Nick McCardle
Sep 10, 2015 08:36 PM
BOOT77
Sep 5, 2015 03:55 PM
