Oh great, a leak. Pics included
Old May 18, 2006 | 10:53 PM
Animus's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock 2.7whatevers
I take it this isnt good. I noticed it just a bit a while ago but it stayed dry for quite some time. Then I noticed my car was getting hotter than usual and became suspicious. I do have another small leak between the radiator and coolant box but I haven't noticed a difference in the coolant level since winter. The hose just isnt tight enough on the radiator I suppose. So my stab in the dark is this is the heater core, but I could be (usually am) wrong, edit - yeah I'm way off. Looks like the gasket is dying or something. Any idea on what this'll cost me + labor?
Old May 18, 2006 | 11:14 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
do it your self it will cost you a 20$ water pump that comes with new gaskets. cant beat old sbc prices. easy to do just remove some brackets and belts remove pump clean surfaces reinstall new pump and gaskets and reassemble. 2 hour job at most.
Old May 18, 2006 | 11:21 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Under $100 for a decent water pump from Napa and new coolant. Around $250 or so for a shop to do it.
Old May 18, 2006 | 11:29 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
LOL I stuck one of these AutoZone.com | Shopping $11.99
worked for like 5 years till i sold it. Ive spent more on lunch than it cost to do a waterpump LOL
Old May 19, 2006 | 11:26 PM
Animus's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
thanks for the replies.
Anyway, It wasn't leaking today on the way to/from work and didnt overheat like it did when it was wet and I'm out of cash because it's graduation/prom/tons of other **** season so I haven't gotten many hours at work lately. Last paycheck (weekly) was $60 and that's just about gone now and I got it thursday. Gas prices take a large chunk of that lately .
Old May 20, 2006 | 02:36 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
yea just looks like that back plate on the water pump is leaking. possibly fixable without a new pump. but a new pump is like $25 reman and 47$ brand new and remans work jsut fine. doesn't take must to get it done either.
Old May 20, 2006 | 11:59 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
water pump
I had to put a pump on my 92 tpi a couple of weeks ago. I found an aluminum pump on ebay for about $60.00 and it works great. Be sure you get a reverse flow pump since you have tpi.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
zerogsx
Feb 6, 2016 11:29 AM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
