engine temp?
Old Jun 11, 2006 | 11:26 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
engine temp?
what is the normal temp. 4 a 1983 camaro 2.8l? my friends is reading 220 and i thought that was high, also how acurate r aftermarket gauges, becuz he has 1 and is not sure if its the right temp or not.
Old Jun 11, 2006 | 11:41 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
Old Jun 12, 2006 | 01:58 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
220 is right about right, i threw in a 180 degree thermostat because i didn't like the fact that it was warming up that high (i live in an area that routinely sees over 100 degrees in the summer. i have no complaints at all about using the 180 degree, though i do have to change it out ever 2 years for the 195 so i can pass smog...s
Old Jun 12, 2006 | 09:46 AM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i would say yes , for you to pass
Old Jun 12, 2006 | 11:44 AM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
My car has ran as low as 160 on the highway..
But I also have a huge radiator and the sort.
Old Jun 12, 2006 | 08:26 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
accually it was reading 235 for the temp.
Old Jun 12, 2006 | 08:28 PM
Car: 84' Trans Am
o, oops, then 235 degrees
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
