tpi coolant bypass
Old Jun 13, 2006 | 01:33 PM
mikieman98's Avatar
Car: 1985 camaro iroc-z
Engine: 350 4 brrl
Transmission: B&W T5
Axle/Gears: B&W 9 bolt 3.45
tpi coolant bypass
Hi all was wondering if anyone knew how to bypass coolant for A 305 tpi model. have heard that this will give approx. 5 extra horsepower by keeping throttle body a little cooler. thanks
Old Jun 13, 2006 | 03:25 PM
mpayne's Avatar
It may not gain any horsepower but it won't make hot coolant heat up the intake. The intake is already going to be hot though because of heat transfer from the motor but at least it won't be heated further from the coolant. The way I did this was, look at where the coolant lines go from the throttle body. One side goes to the heater diverter valve, the other to the water pump. Remove them. Get a piece of heater hose (I think it's 5/8" and about 2 or 2 1/2 ft. long, trim as needed) and connect one side to the heater diverter valve and the other side to the water pump, effectively bypassing the throttle body.
stalkier
Dec 6, 2015 11:25 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
