weeping water pump fitting
Old Jul 3, 2006 | 02:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The top of my water pump has the fitting to go to the heater core. It's a cast iron pump i'm guessing, and a brass fitting. I put it in with permatex thread sealer, with teflon, say, 2 months ago. Just recently I noticed it weeping from the threads of the fitting.
I removed the hose, removed the fitting, cleaned the threads, and put a bunch of sealant on it, and put it back on. It's still weeping from the sealant covered threads, very slowly.
Is there a torque spec for this fitting? I can't really get a torque wrench on it, but i'm hoping for a ball park?
Should I try a hardening sealant, like red RTV?
Is this a common problem, a sign of a different issue or....?
Old Jul 5, 2006 | 03:06 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
REPLY TO A THREAD ABOUT THREADS
There is no need
to gook-up your threads.
Teflon tape will provide a leak-proof
seal while keeping the threads in new condition,
make it faster to R&R that connection,
and you will not have to over-tighten connections.
Happy Racing !
- If people drove any slower
they’d be going backwards -
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
