'91 LO3...fan only turns on when A/C is on
Old Jul 6, 2006 | 08:49 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I assume the switch is bad? The fan works, but only when I turn the A/C on!
Old Jul 7, 2006 | 07:06 PM
facelessnumber's Avatar
Car: 91 RS
Engine: L03 carbed
Transmission: 700R4, rebuilt+kit
Axle/Gears: 3.42, posi, disc
You could be right, but it might also just never be reaching the insane temp that the factory set your fan to come on. It's somewhere around 230 I think. Way too high in my opinion. But then I'm not a GM engineer...
There's a sensor under your passenger side exhaust manifold with one wire on it. Ground that and see if your fan comes on. If it does, then it's either that sensor or it just isn't reaching the temp to trigger it. (you can replace it with a lower one if you want) If it still doesn't come on, you have some other problem; burned wire, etc...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
85Special
Sep 3, 2015 04:21 PM
andy74
Sep 3, 2015 08:41 AM
