does the A/C use the stock computer for anythng
Old Jul 9, 2006 | 10:31 AM
BOTTLEDZ28's Avatar
Transmission: A4
Just need to know if the stock computer is wired into the A/C system at all. I didtched my computer and all the wiring attached to it and replaced it with a FAST ECU and wiring harness. I want to put A/C back in my car and need to figure out the wiring part of it now.
Old Jul 9, 2006 | 01:22 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The A/C sends a signal to the stock ECM to tell the engine to idle up under load. This also kicks on your second fan. I recently finished A/C on my LT1 and I forgot the wire that sends the signal. My car will actually die at a stop light and surges everytime the compressor cycles
Old Jul 9, 2006 | 01:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
wonderful. Now i gotta figure out how my FAST ECU can manage to do that.
Old Jul 9, 2006 | 05:33 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Might want to check out your IAC, it should more than be able to compensate, the one LT1 swap i've done that I hooked up the a/c for had no problem with the idle when the comp cycled.
Bottled: your ecu may have an input, if not heck even if so, i'd bet it will compensate on its own.
sweet_87_iroc
Sep 25, 2015 10:01 PM
BikeFarm
Aug 11, 2015 11:35 PM
Thirim
Aug 9, 2015 06:19 PM
