Will a 160 stat throw out a code 32?
Old Jul 27, 2006 | 01:27 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I just installed the 160stat on Sunday. And last night on my way home from work I threw a code and it was 32 for the EGR. I checked the connections and all are well. Would the 160stat cause this? Something about the coolant being colder than 176* during closed loop? Will this harm performance?
Old Jul 28, 2006 | 10:44 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If you lower your t-stat rating, you need a "cooler" chip. The computer needs to know you're running cooler on purpose. It could be connected, howerver I personally have never heard of such case.
Reprogram your memcal to accomodate the lower temps and see if the problem goes away.
Lou
Old Jul 28, 2006 | 07:09 PM
Car: 1994 Trans Am
Well, it only came on once a couple days after I put it in. I've driven it 2 days since and it hasn't come back on. Will a 160stat lower performance as well? Because my car doesn't feel quite so super. I'd say 75-85% power it used to have.
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
Nervous2
Oct 8, 2015 10:53 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
ndndndnd
Sep 28, 2015 08:00 AM
