Blower motor question
Old Aug 13, 2006 | 12:28 PM
thirdapollo's Avatar
Has anybody figured out a way to make the blower motor run faster in a '92 camaro? I mean honestly, it should put out double of what it does, it just doesnt seem enough. Especially in the florida heat, it just doesnt blow enough cold air to cool you off. Is there another motor I could use without too much fabrication, or should i just run some real thigh gauge wire to it? Any ideas? Thanks in advance.
Old Aug 13, 2006 | 03:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This is a frequent complaint (I purchased a new motor and was quite pleased with the outcome--probably because my fan was 20 years old or so). A is always a good idea on this site. Wecome by the way.
JamesC
Old Aug 13, 2006 | 05:54 PM
I didn’t do a search but I did do a quick scan of what was posted. Must of missed it, I did buy a new motor and it still blows a little pathetic I am thinking or running some thicker wires to the blower may this will help. My other thought is to use a motor from an electric fan. There is room but I was hoping someone already did all this I know a motor like this will pull a lot of amperage.
Old Aug 16, 2006 | 04:34 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
u sure u dont have vacuum leak?
if u do have a leak it will weaken the ac air.
Old Aug 17, 2006 | 07:27 PM
No vacuum leak no leaks anywhere. I just want a way to put more air out. I am going to the junkyard this weekend I am thinking of pulling the motor from a ford tours. It puts out 6000 cfm I am also planning on fabricating a more efficient squirrel cage. Does anyone else have any other ideas?
Old Aug 17, 2006 | 08:30 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i would have to say theres a good chance theres a restriction of some kind inside the system or a door not opening up very much or a mouse nest or something else going on, yours should be putting out as good of air as one that does put out good air, like they were when they were new
something has happened over the years in the system to restrict it
common problem, happens all the time
and it sucks
hope you figure it out
Old Aug 17, 2006 | 09:35 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
I agree with fast68,is there any restiction in airflow at the evaporator core?I know if they leak,the oil will tend to trap unwanted debris there.
Old Aug 17, 2006 | 11:13 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Will it work?
Wait a minute, you mean putting a blower motor from a Ford Taurus?
Is it a direct fit?
Will it require any mods?
If that works, then you have solved a problem that many a third gen owner have faced.
PLEASE respond back if you get this to work, I would LOVE to get into my car, and have a nice refreshing WOOSH of cold air as I get seated.
Old Aug 18, 2006 | 08:45 AM
liquidrider3214's Avatar
how do i get to the blower assembly it doesent seem to be hooked up for the a/c or the heat. i just bought the car and it has no air flow what so ever the guy siad that he disconnected the a/c but didnt say anything about the heeter and now it doesent work, so im assuming that its disconnected anyone know were it is pictures are great?
Old Aug 18, 2006 | 09:10 AM
JamesC's Avatar
Maybe this link will be helpful:
https://www.thirdgen.org/forums/cool...er-heater.html
JamesC
Old Aug 24, 2006 | 10:25 PM
I have the Ford Taurus motor and squirrel cage to both units its very easy to see why this motor puts out more I am working on a mount this weekend ill tell everyone where it takes me.
Old Nov 7, 2006 | 06:27 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Any updates regarding the Ford blower motor ?
Old Nov 23, 2006 | 04:38 PM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
Hey what happend with the blower mods???
Old Nov 25, 2006 | 12:47 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Axle/Gears: 3.42 / 3.42
yes, i'd like to know about these mods too!!!
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
