1984 t/a a/c wiring diagram Needed please!!
Old Aug 14, 2006 | 08:33 PM
esvsr71's Avatar
Car: 1984 trans am
Engine: 305 V8 4bbl carb
Transmission: beats me i don't know much about cars
Hi all, I need some help with my a/c system. I had it recharged today and found out the compressor wouldn't come on. We tested the fuses and the fuse holder and power was coming from it, we jury rigged the plug to the compressor and it worked. But the problem is that if I use the max a/c setting and the max fan setting the compressor will not turn on. So I need a wiring diagram for a 1984 trans am a/c system. We think its either a pulled out wire from the back of the a/c - I'll take apart the center console to get to the a/c controls. If that's not it, it has to be a open circuit where power is not getting to the compressor. So I really need a wiring diagram for this a/c system please.
Jeff
Old Aug 14, 2006 | 09:13 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You can find the appropriate diagram on our ATGO wiring diagram page. Click on the body wiring for your year.
Did you check the A/C dryer low pressure switch? That is often the culprit. Does the system have enough refrigerant? If the compressor turns on only with slow blower setting, it would point to low pressure in the system.
Hope this helps.
Lou
colton_carlson
Mar 8, 2019 12:21 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
