A/C Leak????
Old Aug 16, 2006 | 11:53 AM
Joker1232's Avatar
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
A/C Leak????
92 z-28....so i figure my control unit is fried so thats why its stuck on defrost...but i still cant find the leak. I used the UV freon to look for any leaks but only place i saw the UV was on the low pressure plug where u fill it(could have shot on it when i took the plug off of it).....is there anywhere i might not be looking thats hard to see??? I fully recharged the thing twice and by the next day the clutch was clicking on and off because the pressure was to low and it didnt blow cold anymore. If its leaking so fast there must be a big leak....could it be the plug?????
update---Looks like its coming from the compressor, Damn! can it leak from the compressor if the compressor is bad? the clutch engages...
Old Aug 16, 2006 | 04:24 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
the heat/AC system is vacume powered so that at a loss of Vac your car will default to Defrost so you can at least see outta the winshield to drive. In my sisters old bird there was a small 2 inch dia .25 inch thick octopus looking vacume distributition thingy that controlled where the air went ie heater, floor, vents, defroster. might lok into that. sounds like it is leaking and thus defaulting to the defroster setting. Im memory serves it was about 15 bucks for the part.
Old Aug 16, 2006 | 07:36 PM
Joker1232's Avatar
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
Ok so i came home and checked it out again.....the compressor has UV stuff all over the back of it....looks likes the freon is comin out if the inside of it somehow, prob seeping out of it?!? Any1 heard of this eva happening????
Old Aug 17, 2006 | 12:07 AM
Car: 89 RS
Engine: 2.8
yep. your car is 14 years old. things wear out. you are going to have to replace that, and wile you are at it micght as well do the condenser and evap tube at teh same time. that way it will ALL be nice and fresh.
Sorry if my first reply was not what you needed, but thought you said your control was locked to defrost....
Old Aug 17, 2006 | 09:52 AM
Joker1232's Avatar
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
Oh hey that is locked up too, i am def gonna check out those lines, do they break alot under the dash???? or usually just get bent or something, i've read u have to take the dash apart to change them
2012sergen11
Oct 13, 2015 07:38 PM
timonator
Sep 30, 2015 12:52 PM
BLK87Z
Sep 18, 2015 11:29 PM
bubbaz28
Sep 18, 2015 02:09 PM
Mdenz3
Sep 17, 2015 08:36 AM
