Water pump on its way out?
Old Sep 6, 2006 | 10:06 PM
zdc590's Avatar
So i was driving my car a few days ago (305 tbi) and about 5-10 minutes after i left my house i noticed the temp was pushing 260. I didnt even think it could heat up that fast but i turned on the heat hoping for a quick fix and it went back down to around 180. Itll bounce around now anywhere from 240-180ish. My brother suggested the water pump was stopping every now and then causing it to heat up really fast, then cool down a bit. Anyway, i just wanna get your opinions on this before i go spend some money. Also, if it is the water pump, is it an easy fix, and details about putting a new pump in would be helpful. Thanks
Old Sep 7, 2006 | 06:31 AM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
The water pump will not just stop pumping. It is a belt driven water pump.
Sounds like you may have a sticking thermostat or your lower radiator hose may be collapsing.
Old Sep 7, 2006 | 04:16 PM
zdc590's Avatar
Alright ill try and check those out too, thanks for the ideas.
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
