Searched, tested, still a negative!!!!
Old Oct 26, 2006 | 06:59 PM
missouraman's Avatar
Car: 1991 trans am
Engine: 5.0l TPI
Transmission: 700 R4 Auto
Axle/Gears: Don't know... DO U!
Ok first off i searched and got lots of things to test/change. Did them ALL!!!
Here is the problem : Primary fan ( driver side ) will not kick on at 226 temp.
Will kick on : over heat 140, A/c turned on, And checking for codes.
All new sensors / relays. Computer reads proper CTS Temp.
The kid before me had a dangling manual switch under the dash when i bought it. Looked at wires and it all looked hooked so the factory would take over. Well i left it like that and never used the switch until i put a 160 in there. Decided to put a man switch in and would just use his wires and just relocate ( mount ) a new switch. Well after getting under the hood i seen that he had a hot wire ( +12 volts ) from the switch to the Neg. ( ground wire ) that goes to the ecm... I have no other problems it seems, no codes. Just ecm won't kick on Primary fan when should.
Replaced
CTS.
ALL Relays
Sensor in passanger side head and sensor in driver ( thought guage was wrong at first )
Tested all.
I just want it Right. Any suggestions would be helpful
Thanx
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
