a/c / heat question
Old Nov 1, 2006 | 12:24 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
a/c / heat question
since my heater core leaks and its no good no more, if i put my a/c(it works) and put the a/c air on warm for some heat would it work witout the heater core leaking
Old Nov 2, 2006 | 03:05 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
If your heater core is leaking, why not take the time and make the effort to replace it? If the heater core is leaking... you're loosing coolant. If its dripping inside of the car, that's plain nasty. If it's leaking under the hood, the (engine) cooling system is not as effective as it should be.
A new replacement heater core will run you about $25+-. from Auto Zone.
You should replace the hoses on the firewall while you're at it. $35.+-
Three gallons of anti freeze, about $20+-.
Figure about $100. out of pocket to fix if you do it yourself.
Frozer!!!
Jan 19, 2024 04:55 PM
zayne0
Aug 24, 2015 07:22 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
