Hood Insulation known to cause problems?
I noticed the cap to the overflow tank has left an indention in the hood insulation. Also, the coolant in the overflow has what I would call a lot of black dust or black fine dirt in it.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Never had that problem when my Res tanks were monuted on the stock location.Maybe cutting the insulation just around the cap will help.Definitely change the coolant in the overflow tank.
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Im suprised you havent just taken the insulation off yet. The only thing it provides is sound deadening. Having it off will not effect the paint - on niether a fiberglass nor steel hood. Plus, it sounds like yours is nasty and flaking anyways.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
3rdgenparts
Aug 6, 2015 09:03 AM
