Constant Ground at Fan Relay (green wire)
Old Dec 13, 2006 | 06:27 AM
RisingSunIROCZ's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 9
I am assuming this is happening because the computer wants the fan running. What sensors/input cause the computer to ground/complete the circuit? I know the AC press. and CTS go to the computer, but what actually trips ground? I just completed a motor swap, and removed my AC. I jumped the AC pressure switch (black and blue wires) and the green wire is still grounding. I did download some wiring diagrams (bad pic of one attached) I want to wire one relay to the computer, and one relay to a toggle, since i no longer have the sensor in the pass head to trip ground for the other relay. I want to eventually wire both of them together to turn on from the ecu, but if they will both be constantly running, i would rather just toggle one. Also, just looking for a quick fix for now, as I am shipping the car from Japan and just need it to make it through shipment and them from Seattle to Spokane. Thanks for everyones help!
File Type: doc
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
