What's broken if your electric fan doesn't turn on with the A/C?
Old Jan 4, 2007 | 09:01 PM
briwar454's Avatar
Car: 1985 Trans Am
Transmission: THM 700-R4
Axle/Gears: Stock
So i found out that my single electric fan is supposed to come on when the A/C is turned on in my 85 trans am with 305 TPI. I don't know where to begin to solve this problem. any help would be "COOL."
Old Jan 5, 2007 | 07:05 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Check the wiring diagrams for '85 within the tech articles. You'll find that the fan relay kicks on the fan when it's grounded. For the A/C it is either grounded through a pressure switch or the AC control head.
Old Jan 5, 2007 | 07:07 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
IIRC its the pressure switch...
Josh
Old Jan 5, 2007 | 08:33 AM
naf's Avatar
naf
I thought so too, but I checked the wiring diagrams for an 85 and VIN F shows a ground through the AC control head. Doesn't mean it's necessarily so though...
Old Jan 5, 2007 | 11:05 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
It is definately through the A/C control head. But you really should make sure the relay is still good before tearing into the wiring or the dash.
Old Jan 5, 2007 | 11:08 AM
naf's Avatar
naf
You can check the relay by jumpering the ground lead to a chassis ground. If the fan still comes on by the temp switch though that would rule out the relay as well.
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
TheExaminer
Aug 19, 2015 10:07 PM
ZsTransAm
Aug 11, 2015 07:30 PM
