Help, no air coming out of any of my vents!
Old Jan 13, 2007 | 10:53 AM
tlgrooms's Avatar
Car: '69 Camaro/'91 Camaro/'93 Camaro
Engine: 307/305/350 LT1
Transmission: Powerglide/Auto
Recently changed the heater core on my '91 Camaro RS and now I have NO air coming out of any of my vents, not even the defroster vents. Replaced the fan a couple of years ago and it is blowing great.
Where do I start?
Thanks in advance.
Old Jan 15, 2007 | 10:44 PM
1989CamaroLT4's Avatar
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
If your fan is definitely working then it has to blow out somewhere. I think the default is out the defroster vents even if all the doors don't work, isn't it? I'd check to see if it works with the AC, and if not then I'd check the plenum to make sure it is intact from the heater box to the vents. Other than that I can't figure why you wouldn't get air somewhere. Last resort is checking the fan wheel to make sure it isn't free-wheeling on the fan motor - but that would be a bizarre problem.
Old Jan 15, 2007 | 11:15 PM
Chevyz2882's Avatar
Car: 1982 Z28
Transmission: 700-R4
Check the wires that connect to the blower motor, Mine have come loose before.
Old Jan 16, 2007 | 12:05 AM
tlgrooms's Avatar
Fan is blowing great. Air comes out by the heater core if i leave the plastic cover off under the dash but doesn't come out any of the vents if I put the plastic cover back on.
Old Jan 21, 2007 | 11:02 PM
tlgrooms's Avatar
Maybe I wasn't clear enough when I originally posted the message. Fan is working great in the car, replaced it a couple of years ago. Air was blowing out of all my vents but I wasn't getting any heat. Replaced my heater core and now have heat blowing past the heater core into the passenger floorboard if I leave the covers off under the dash. If I replace the covers under the passenger side dash, I don't get any air out of any of the vents, not even the defrosters.
Old Jan 21, 2007 | 11:04 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
you probably put the litte selection valve in the heater box in incorrectly.
Old Jan 21, 2007 | 11:14 PM
tlgrooms's Avatar
Is this what selects between heat or air? That seems to be working.
Old Jan 21, 2007 | 11:31 PM
Toehead's Avatar
scratch that then
Brinkkl2000
Aug 4, 2018 08:29 AM
chazman
Aug 22, 2015 02:01 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
