Gauge
Old Feb 8, 2007 | 04:51 PM
anakh's Avatar
Gauge
Upon starting the car the heat gauge is maxed, but the vehicle does not seem to be overheating, is it more likely that the gauge is bad or that there is a bad wire somewhere? Everything else on the dash seems to be operating correctly
Old Feb 8, 2007 | 07:54 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
When mine did that the gauge was loose in the cluster. Pull the bezel off and reseat the gauge, and see if that fixes it.
Old Feb 9, 2007 | 07:41 AM
anakh's Avatar
ok thanks I will check that this weekend.
Old Feb 9, 2007 | 11:05 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
they sometimes will get stuck on crank start up when it gets the electrical test signal
happens when the guage is worn out, old, they will peg out and can get stuck,
common problem
good luck
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
