82-85 LG4 cooling fans did they use a spacer ?
Old Feb 9, 2007 | 01:30 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
on the LG4 mechanical fans did they use the removable spacer like some other applications did ? or no ?
if they did use a spacer then how thick are they ?
pic of one of the correct fan assemblies ? spacer ?
thanks
Old Feb 9, 2007 | 01:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, they're clutch fans. The fan clutch is the only thing that goes between the water pump and the fan.
It looks something like this, usually doesn't have so many blades on the fan, though.
Old Feb 9, 2007 | 01:59 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok, cool, thanks
so how many blades were on the fans in these cars ?
and what diameter were they ?
i want to make sure i have the right one for my 82 LG4 t/a
thanks
Old Feb 9, 2007 | 03:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Most cars had a 3 blade fan with just an upper fan shroud. Some had 5 blades with both an upper and lower shroud. Both are about 17" diameter or so.
Old Feb 9, 2007 | 10:19 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I will take a look at my fans tommorow for ya.
Old Feb 10, 2007 | 05:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 85 had a five-blade (it's sitting in the garage) with upper and lower shroud.
JamesC
Old Feb 10, 2007 | 09:23 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
My '83 had a 7 blade fan with thermo clutch and upper/lower shroud assembly.This was part of the HD cooling package.I say had because I switched to factory dual electric(the clutch had failed on my anyhow).
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
