i need a new water pump
Old Mar 6, 2007 | 09:40 PM
1988-305-tbi's Avatar
so i replaced my original water pump last year, at 110,000 miles, because it started to leak. i rplaced it with a new one from auto zone, and it sucks, i have a fan switch on my car and a 160 thermostat, with the old pump the car would stay exactly at 160 degrees not a degree more or less, witht the new one it overheats i always have the fan switched on and if i let the engine idle for 10 minutes and then check the temp it will be at 190, with the fan running the whole time, then if i bring up the rpms, 2,000, for a minute the temp will drop, even while i'm cruisng around town at 40 m.p.h. in cool weather with the fan switched on the car will still range between 160-190, so my pump definately isn't flowing enough. if i pull the cap and watch the radiator flow i can see that its only flowing 1/2 of what the stock one did
so where can i get a better pump, i dont need anything crazy my car is stock with bolt ons, i just need a pump thats as good as factory, for less than $150 bucks, so what is everone using on here?
Old Mar 7, 2007 | 01:43 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you did take advantage of the warranty on the junk new one right ?
ive never had such trouble with new pumps and ive replaced a billion of them over the years
hum
wierd,
have you tried a napa one ?
never gotten anything junk from them ever
or from o reilly auto parts either
i quit going to auto zone when o reilly auto was built here a couple years ago
good luck
Old Mar 7, 2007 | 01:47 AM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
I use edelbrock's water pump. I got a 180 thermostat, my fans open at 220. With my stock pump my car's average temp was 220 now with the edelbrock pump it barely goes over 180. I bought it from summit.
Old Mar 7, 2007 | 03:47 AM
i've gotten 2 bad parts from autozone, my egr, wells, it so stiff the valve wont open, and my water pump, right after i installed the new on i noticed a difference, but i thought that maybe there was air in the pump or something but after a year and 10,000 miles i'm guess ing it just $hit, k-0 how much did that edelbrock pump run you?
Old Mar 7, 2007 | 05:04 AM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
I bought the unpolished one for about $150.
You can check it here ;
http://store.summitracing.com/partde...0&autoview=sku
Old Mar 7, 2007 | 08:51 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Edelbrock aluminum hi-flow water pump. 9 years later and no problems.
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
