wiring fan to relay
Old Mar 15, 2007 | 05:57 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
wiring fan to relay
i have my fan running to a switch..and keeps burning out the switches..thats how i bought it...i was wondering how to wire the relay up to the fan and the switch..cuz there tons of wires on the relay..thanks, Mike
Old Mar 15, 2007 | 06:43 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
OEM relay or aftermarket one?
If it is just a normal relay from a auto store there will be 4 plugs on the bottom of it,
1 you ground, 1 is main power (heavy wire direct from batt), 1 is main power out (Heave wire to fan) and the last is a power wire from a switch (Direct power to switch then wire from switch to relay).
Just mount the relay near youre battery, That is what i did.
I used a free 40A relay out of a wrecked Toyota and i havent had a problem with it.
EDIT: U got Dual fans or a single, i had to run 2 relays 1 for eatch fan, I duno if 1 40A relay will run both if you have duals.
Old Mar 15, 2007 | 06:45 PM
xgtharo86x's Avatar
Car: 86' Trans am
the oem relay on the side of the radiator there are so many wires
Old Mar 15, 2007 | 07:02 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Here is a simple schematic I drew up at work. This should get you started in the right direction at least.
Old Mar 15, 2007 | 07:07 PM
xgtharo86x's Avatar
Car: 86' Trans am
thanks man,that will help but i dont no what wires to use on the OEM relay there like 12 coming out of it
Old Mar 15, 2007 | 07:45 PM
VenomX-87's Avatar
umm sry can't realy help there 80% of my OEM wiring has been gutted/Hacked out when the old owner had it converted to RHD back in 1987.
Old Mar 15, 2007 | 08:55 PM
xgtharo86x's Avatar
Car: 86' Trans am
thats alright..your cars right hand drive thats pretty cool
Old Mar 15, 2007 | 09:31 PM
VenomX-87's Avatar
thx, Wait IF you are running the fans off a manual switch there is a chance the OEM system was not working when you got the car.
If you just want to start over with the current system Get a basic relay Cut the wire going to the fan (about 12" from the fan) then put That wire going to the fan on the main out plug of the relay (plug 1) then hook main power to the other side of the relay (plug 2), use the old wire coming from the switch (in cab) on the relay (plug 3) and then ground the other side of the relay (plug 4).
That should work without burning out anymore switches.
i will post a pic soon, at work ATM.
Old Mar 15, 2007 | 09:33 PM
xgtharo86x's Avatar
Car: 86' Trans am
thanks man--so i just go to the autopart store and ask for a relay for a fan and switch?
Old Mar 15, 2007 | 09:46 PM
VenomX-87's Avatar
I don't know what guage wireing it will want the guy at the auto parts store should know.
But just ask for about 2 feet of wire, a 30A or 40A 4 pin relay and some spade connectors.
That should do it, if u need any help just P/M me. Good luck dude.
Old Mar 15, 2007 | 09:47 PM
xgtharo86x's Avatar
Car: 86' Trans am
thanks man ill let you know
Old Mar 15, 2007 | 10:31 PM
VenomX-87's Avatar
sorry it is realy rough, i rushed it (still at work)
Old Mar 15, 2007 | 11:00 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Only thing wrong with that is ground should be switched instead.
Old Mar 15, 2007 | 11:27 PM
VenomX-87's Avatar
realy, whys that? not tryin to sound rude.
i just set mine up like that because i wired a second fan in there and it seems to run fine like it, I have had it in there for 4 months now with no problems.
If it will be an issue i will change mine, just reverse relay to fan?.
Old Mar 15, 2007 | 11:40 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
That's just the way Chevy wired them. I guess if you want to start from scratch you could wire anyway you want, but if you just want to add a switch, break the primary ground wire at the stock relay run it to the switch and then ground the other side of the switch and you're done.
Also if you're running a long ground wire from the relay to the switch and it becomes cut or frayed and touches the chassis no big deal.
Old Mar 17, 2007 | 10:01 AM
MAC25DM's Avatar
Car: 1988 Firebird
Engine: 2.8 liters of fury.
Axle/Gears: Stock
My fan wiring was all jacked up when I got my bird, so I just got a temperature relay that kicks on the fan automatically. It's got a little probe at the end that touches the radiator. I have it set to kick on about 210. Works pretty good and only required two wires, no switch. The best part is that I can adjust it to come on at a higher or lower temp. Works for me.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
