a/c compressor question
Old Mar 19, 2007 | 10:21 PM
88trans_am_gta's Avatar
Car: '88 gta
Engine: 350 tpi
well, i hope i picked the right board for this.
im fairly new to third gens, at least ones that have a/c that works.
my problem is that the compressor makes a horrendous whine while in idle, but not in drive. so anywhoo, i turn on the defog tonight and switch between hot and cold to make sure everything worked. i turn the slider back to hot and start hearing a noise like something engaging then disengaging. pop the hood to see the pulley from the compressor spinning then stopping. its not the actual pulley, but the front part of the pulley <unfortunatly im not sure of the name, sorry.> is this normal, cause i dont think ive seen my buick do it.
Old Mar 19, 2007 | 11:27 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
That loud noise is the aircon clutch slipping (I duno if it can be replaced) That is why it is not working. when it is switched on the clutch plate is pulled in and engages the pully if it pulls in but dose not grip the pully it will make a high pitch squeal and the aircon wont work.
Old Mar 19, 2007 | 11:54 PM
91_rs-teal's Avatar
Car: 1991 Camaro, Best 12.40 @ 115.8 MPH
Engine: LS1, HCI, Headers
Transmission: T56, Monster Stg. 4
Axle/Gears: 7.5" 10 Bolt - 3.73's w/ posi
engage and disengage is normal... A/C de-humidifies the air then cools so, when your in defog its kicking on then off to take some moisture outa the air inside the car to "defog" the windshield
Old Mar 20, 2007 | 11:32 AM
Car: '88 gta
Engine: 350 tpi
Re: a/c compressor question
hmm, alright, i see what your saying. well, if it does go bad, fortunatly i have another one off a camaro. thanks a lot guys.
Old Mar 21, 2007 | 09:19 AM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
Very short cycling (rapid engage/disengage) can also be a symptom of a system that is low on refrigerant. If your A/C is cooling properly then this is probably not the case.
Old Mar 21, 2007 | 07:06 PM
Car: '88 gta
Engine: 350 tpi
well, i know the guy i bought the car from had i converted to r-134a, and it blows pretty darn cool. i dont know much about a/c, but more than likely if the compressors bad, ill probably just gut it.
Frozer!!!
Jan 19, 2024 04:55 PM
zayne0
Aug 24, 2015 07:22 PM
redmaroz
Aug 16, 2015 11:40 PM
Thaney9
Aug 7, 2015 08:25 PM
