Fans...
Old Mar 24, 2007 | 01:39 PM
bowtiesis_z28's Avatar
Fans...
Hi I'm stacey, I'm 19 and I own a 91 RS. My car has been overheating and I replaced the thermastat I just got done draining the radiator thinking it might be clogged because my antifreeze just turned to a nasty brown, and its not leaking so I don't think my water pump is out. Can anyone please direct me somewhere or can someone tell me what temp my fan should be kickin on at?
Old Mar 24, 2007 | 08:37 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: Fans...
Your fan should be kicking in around 190-210, but it also depends on what engine you have. If the fan is not kicking on, replace the relay after checking the fan motor itself. All you have to do to check it is jump the fan leads to the battery real quick and see if it spins. Chances are it's a faulty switch or relay.
My favorite solution to the whole fan problem is a manual switch- just be sure to not let your friends drive the car after you put the switch in- they will never turn it on, even if you tell them to Hope this helps,
luvofjah
Apr 18, 2015 02:18 PM
kthxbai
Aug 13, 2014 09:55 PM
bad_to_the_bone
Jun 23, 2011 08:02 AM
Kevman
Jun 4, 2011 07:40 PM
liteumup387
Aug 19, 2009 06:50 PM
