cooling fan stays on
Old Apr 4, 2007 | 05:42 PM
govenorcamaro's Avatar
I have an 87 iroc-z and the cooling fan stays on all the time and the second one doesn't come on at all the car stays cool but wandering if this is normal it's an 87 350 tpi. auto dual fans and I have an 91 305 tpi 5 speed formula car that does the same thing any help would be appreicated thanks.
Old Apr 4, 2007 | 06:04 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: cooling fan stays on
Coolant temp sensor under the throttle body (the computerized one, not the analog one on the side of the block) has gone bad.
Old Apr 4, 2007 | 06:24 PM
even if the engine light is not on, or does not read that code
Old Apr 5, 2007 | 07:42 AM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
It sounds like the relay for the primary fan needs to be replaced. I had this same problem a few years back.
Old Apr 5, 2007 | 11:07 AM
thanks I will try those things and get back to you
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
