temp sensor
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: temp sensor
Right side of the block should be the fan switch one wire, left side should be for the guage one wire spade conn the two wire in the intake by the t'stat is for the ECM
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
Re: temp sensor
k which is it.i got 1 person sayin passenger n driver.i foound 1 on the driver side wit 1 black wire coming out of it and its got a gold thing holden the wire on.i tryed pullin on it but couldnt get it off.help
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: temp sensor
ok this is what they are
1: Drivers (LH) side head there is a sensor for the (in cab) Temp guage.
2: Passenger (RH) side there is a temp sensor to activate the fan (Dual fans only i think).
3: Intake there is a sensor for the ECM.
I thought only the dual fans had a passenger (RH) side senser to turn the secondary fan on coz the main fan is controled by the ECM.
If im wrong someone will corect me, Hope it helps.
Car: 1991 Camaro Z28 Clone
Engine: 350 w/TBI
Transmission: WC T-5
Axle/Gears: Spicer 3:73 Auburn Posi
Re: temp sensor
There is still a temp sensor on the Pass side that controls the main fan even if you only have one. Joined: Jun 2005
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Car: 89 Firebird
Engine: 350 Ramjet
Re: temp sensor
Rt head between #4 and #6 cylinder.
there is a picture of the fan switch in this thread
https://www.thirdgen.org/forums/cool...an-switch.html
Car: 86' Z28 Camaro
Re: temp sensor
k is the driver side 1 have 1 black wire???? and is there a sertain way to take the wire off casue i tryed ppullin it off n would come off
Car: 89 Firebird
Engine: 350 Ramjet
Re: temp sensor
pull the connector the same direction the wire is going and it will slide off. keep it parallel to the block and you shouldn't damage anything.
Car: 86' Z28 Camaro
Re: temp sensor
is the medal thing jst a cap like a protection thing cause i still cant get it off.and is it located by the fire wall on the driver side like attached to the header area?? casue that were i see it
Re: temp sensor
nah the drivers side temp sensor is closer to the front of the engine under the exhaust manifold.
It looks like a spade connector.
Car: 86' Z28 Camaro
Re: temp sensor
i need to kno were the temp sensor wit the guage goes.i forgot to right the guage part.is it in the same spot or pass side
Re: temp sensor
wait... is youre car RHD or LHD?
If LHD it is in the drivers side head near the front of the engine.
If RHD it is in the passenger side head near the front of the engine.
Car: Z/28
Engine: 355
Transmission: Turbo 400
Re: temp sensor
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
Re: temp sensor
mine was on the intake manifold by the thermostat housing
Re: temp sensor
well when i got my car my setup was:
Fan Temp Switch was in Intake next to T/Stat housing.
In cab temp guage sensor was in LHS head (Close to the front of the engine)
and that is it. No ECM and a hacked up wiring loom.
I now have:
Fan Temp switch in same location with a new aftermarket temp guage sensor right next to it in the Intake, the OEM guage sensor is still in the LHS head but it is only as a guide since i have not put the aftermarket temp guage in the cab yet (hookd up under the hood next to the battery).
The aftermarket one was only installed to get a idear of how close the OEM guage was and to tell me at what temp my fans were coming on.
I now have:
Car: 86' Z28 Camaro
Re: temp sensor
did u have to feel for it? like u couldnt see it only feel it under by the header area.i felt it and the end of what im hopin is the sensor...but the end was round.i have this green wire hangin and at the end where it should clip it has a speaker like clip.
Re: temp sensor
YES!!!! thats it, the spade conector (green wire) slides over the round end.
If you still have aircon then Yeah it will be almost imposible to see.
Car: 86' Z28 Camaro
Re: temp sensor
nice im gana try it today
but how is it supoosed to go on the round end?????its made to fit in a sqaure peice not round.,,
Last edited by 86V8Z28Camaro; Apr 17, 2007 at 08:32 AM. Reason: Automerged Doublepost
please
