water only in coolant bad?
Old May 29, 2007 | 11:06 PM
PAformula's Avatar
Will running only water in the summer hurt anything?
Reason I ask is cuz the car was purchased with rust built up in the raditor and the coolant was brown. After draining and flush many times its has cleared up but the radiator is still rusty inside.
also, Any tips for removing the rust build-up?
Old May 29, 2007 | 11:36 PM
83Chevy__Camaro's Avatar
Re: water only in coolant bad?
replace the radiator and use antifreeze, no exceptions
Old May 29, 2007 | 11:57 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Water only doesn't hurt anything.
Buy a chemical flushing agent and flush with that.
Old May 30, 2007 | 12:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Straight water has a lower boiling point than a water/coolant mix, and doesn't have any of the anti-corrosion agents that are in coolant.
Old May 30, 2007 | 01:31 AM
R Scott's Avatar
Car: 1991 Camro RS
Engine: 350 TBI
Axle/Gears: 9 Bolt, 3.45:1
Straight water does have a lower boiling point than a water/anitfreeze mix, but it also has better cooling properties. The 15 to 16 psi that the cooling system is pressurized to will actaully provide the raised boiling point necessary. If you want to run only water, then you should add something like Prestone anti-rust into the system. This will prevent the corrosion issues.
I live in Phoenix, Arizona where we don't have much need for anti-freeze protection in the winter, so I have ben running this setup for years without issue.
Old May 30, 2007 | 02:29 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i run straight water just because i went through 3 cases of antifreeze from leaking head gaskets, head swap, intake swap, motor rebuilds, etc.. just didnt see the need for more money to enter the pot since the coldest it gets in hawaii is maybe 30's with windchill.. and i run just fine at 155 on cool nights and 165 on the highway.. with 175 in traffic on a high 80* day..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
