Possible cooling problems?
Old Jun 4, 2007 | 05:42 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Solved
Old Jun 4, 2007 | 05:51 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: Possible cooling problems?
I think the stock "fan on" temp is around 138'F so it may just need to get a little bit hotter to turn the fan on.
Old Jun 4, 2007 | 06:06 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Do you think its a concern or should I let it be?
Old Jun 4, 2007 | 06:27 PM
VenomX-87's Avatar
Well when you are driving has it ever passed the 3/4 mark on the temp guage?
If you think it is getting too hot (I don't like my engine going over 220'F) you can either install a lower temp switch in the passenger side head or install a manual toggle switch in the cab so you can turn it on when ever you want.
If this is what you want to do find the wire going to the temp switch in the passenger side head and tap into it (you can but clips that go over the wire and cut/join a new second wire into the circut) then lead that into the cab where you can mount a toggle switch and ground the other side of the switch (to ground the fan circut) so it turns the fan on when the ignition is on.
Wire splicers (clips): http://www.radlites.com/images/splice_connector.jpg
Old Jun 4, 2007 | 06:53 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
bessie
Sep 14, 2018 07:08 AM
rebel1222
Jun 22, 2007 11:23 AM
ricktaylor
Apr 13, 2004 02:12 AM
KC10Chief
May 11, 2003 06:36 PM
NXS055
May 8, 2002 07:42 PM
