A/C connector?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
A/C connector?
Got an '87 camaro LG4. There's an unplugged connector coming from the wire harness driver's side near the steering box. It shows continuity to the sensor wire to the rear of the compressor. Where's the sensor this thing plugs into?
Green and Green/black two-wire connector. Power apparently passes through it, to the sensor on the compressor, to the compressor clutch. Did a cam swap not long ago so I must have unplugged it, now it's hot and time to juice the A/C. It comes out of the harness opposite the power steering low pressure switch connector.
Re: A/C connector?
Started looking through different wiring diagrams. It wasn't shown on the one I have in the shop but found it on the web. Power steering A/C cut out switch. Apparently this switch is missing from my ride.
