Trouble Code 23, Killed my Fan?
Old Jun 20, 2007 | 06:47 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
1988 Camaro 350. Single radiator Fan, quit working last Friday at the Drag strip. I am Running a #23 Troble Code,
23.
Low temperature at manifold air temperature sensor OR Throttle position sensor error
Would this have anything to do with my fans quiting?
Old Jun 20, 2007 | 08:36 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Re: Trouble Code 23, Killed my Fan?
Check your fan switch.... Im pullin a code 23 also but thats my TPS i do belive... But im pulling that code and also my fan quit. I couldnt figure it out what was going on. But my dad took it to work and had his mechanic looked it over and he found that the fan switch was bad. Not sure if this is helping or not. But its what happend with my car. Maybe that will give you somehting to look at and see whats going on.
lol oh and also the weird thing is. When my fan quit my windsheild wipers did to... Fixed the switch and now the wipers kick on. Weird...
Last edited by naterman35; Jun 20, 2007 at 08:37 PM. Reason: Automerged Doublepost
Old Jun 20, 2007 | 09:04 PM
Car: 1991 Camaro RS
Wipers Work. Relay is pretty New, As well as the Switch. but I guess I Should replace them both just to do it I guess.. if it works, great, If not.. Whatever. I'm Hooking up a Swich, Right below the Headlight Switch...
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
eustodp
Sep 20, 2015 05:09 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
