driver side fan wont come on
Old Jun 20, 2007 | 09:13 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
My car after driving a long distance if i sit for more then 10 mins the car goes to 220 plus one time almost 240. The car used to be tpi now it is a carb. I checked all the sensors that plug into the ac and there all hooked up and the ecm is hooked up and it still runs my fuel pump and the fan that is controlled by a thermal switch. Before the carb swap it always ran cool it has a hypertech 176 fan switch and a mr.gasket 160 t-stat brand new water pump and radiator. Is that other fan not coming on causing my problem? (tryed to ground the adld and the fan doesnt come on same for when i turn on the a/c)
Old Jun 20, 2007 | 09:25 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Re: driver side fan wont come on
Ive got the Same Probelm, except I have single Fan.
Your Dual Fans Have seperate Relay's. So if one fan isnt Working, it should effect the other.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
LittleFranks
Sep 17, 2015 12:22 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
