I keep pulling my hair
Old Jul 4, 2007 | 11:14 AM
Crazy 84 Z28's Avatar
Car: 1984 Z28 Camaro
Engine: 305 H.O. 72,000 original miles
I replaced the water pump, timing chain (switched to a high performance chain) and all of the gaskets involved to get the car started. I start the car up and the temp guage slowely moves up to where the thermostat should open. When the guage reaches the thermostat opening point the guage skyrockets to the red like the thermostat is not working. I replaced the thermostat about 3 months ago. Dont know what to do. Oh I drive a 1984 Z28 camaro 305 engine.
Any advice would be appreciated.
Old Jul 4, 2007 | 11:37 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: I keep pulling my hair
sometimes you get a bad thermostat from the store. Try testing the thermo to see what temp it opens up at. Boil some water on the stove and use a household thermometer to check its temp once it opens up.
Old Jul 4, 2007 | 02:35 PM
Its crazy because I didnot have a cooling issue before I replaced the timing chain and water pump. I replaced the pump just because I had to take it off to replace the chain, so I decided to get a new water pump so I wouldnot have to do the pump later. My temp guage reads 240 and I shut the car off, I run over and touch the radiator and the lower/upper radiator hoses and none are warm. Its like there is no circulation due to a defective watwer pump or bad thermostat or it could be my temp guage is bad. Need help fast.
[quote=Crazy 84 Z28;3388916]Its crazy because I didnot have a cooling issue before I replaced the timing chain and water pump. I replaced the pump just because I had to take it off to replace the chain, so I decided to get a new water pump so I wouldnot have to do the pump later. My temp guage reads 240 and I shut the car off, I run over and touch the radiator and the lower/upper radiator hoses and none are warm. Its like there is no circulation due to a defective watwer pump or bad thermostat or it could be my temp guage is bad. Need help fast. What really sucks is someone wrecked my brothers car about two days ago and he is using my other car for the time being, luckly I am off for a week thats why I am in a frantic state right now. I need to get this car running again.
Last edited by Crazy 84 Z28; Jul 4, 2007 at 02:39 PM. Reason: Automerged Doublepost
Old Jul 4, 2007 | 04:25 PM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Two things come to my mind...you have your thermostat installed upside down (Seen it many times) or you bought a reverse flow waterpump, put your old water pump back on and see what happens!
wigmobile
Feb 26, 2025 02:56 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
