stock dual fan amp draw and amp?
Old Jul 13, 2007 | 04:48 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I just bought a set of stock camaro fans to replace my old clutch fan . Im not running a computer in my car and I want both fans to come on at once .Car is an 85 iroc with a GM creat 350 with headers , intake and carb
1. Can I run both fans on one 30 amp relay
2. How much ampage will both fans draw at one time .
3. What temp switch should I run on 185 off 170 or on 200 off 185
Old Jul 14, 2007 | 03:05 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: stock dual fan amp draw and amp?
I went from a clutch fan to dual fans on my '83 and I have them on separate circuits with 30 amp relays.A single 30 amp relay will overheat with the load from 2 fans at startup.I used the factory dual fan wiring diagram as a guide.Also I have them controlled by external adjustable thermostats.They come on at 200*F and off at 185*F.
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Leggman1
Aug 6, 2015 04:15 AM
