85 Iroc TPI Cooling fan
Old Jul 21, 2007 | 10:15 PM
moparram's Avatar
Car: 1985 Camaro Iroc-Z
Engine: 5.0 TPI
Axle/Gears: 2.73 posi
I have an '85 Iroc 305 TPI and was wondering if the computer uses the sensor on the front of the intake to control the single cooling fan? I got a fan switch (sensor) for the passenger side cylinder head, but cannot see a connector on the harness that will fit it other than the knock sensor plug!! This car was purchased with the engine and trans removed, so I wasn't the one to "unplug" everything from the motor prior to being taken out!!
Old Sep 22, 2007 | 08:01 PM
Helltrooper509's Avatar
Car: 85 Trans Am
Engine: 305 T.P.I.
Re: 85 Iroc TPI Cooling fan
Hey, did you get this problem figured out yet?
Well if you didnt, there alot posts about this but I can give you some quick info. The sensor in front of the intake is the Coolant Temp Sensor for the computer and does not control the cooling fan. The one sensor (switch) on the passenger side is for the cooling fan to come on when it gets hot enough which "should" be at about 185degrees and has the same plug as your knock sensor. There also should be another cooling temp sensor which is for your temperature gauge and that one is on the drivers side head between #1 and #2 cylinders. This help?
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
