Blind guy needs help finding Sensor
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Legally blind, not totally, I felt everywhere but no luck... I checked my 91 book, no luck either...
I have a 91 TPI 5 Speed. The sensor that monitors the temp and turns the fan on... I think it's close to Driver's side Spark Plug 1... I found the cable, disconnected of course... I can't see that far and I felt every where I could...?? Can you guide me from the spark plug, is it in the block, the head, etc... front / side, etc...??
Thanks in advance
Raf
Thanks in advance
Raf
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Blind guy needs help finding Sensor
the sensor on the drivers side at the front of the head is for your gauge in the car. the one that turns the fan on is on the passenger side in the block between 6 and 8 exhaust ports.
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
right behind the oil dip stick tube. it's really fun
It's the gauge I noticed not moving anymore... and it was previously working...
So front of the head... I assume the front of the motor ?
Again, I found the cable / spade plug, just couldn't find the sensor to plug it back in to...
thanks,
Raf
Update:
Mounts on the driver side cylinder head between cylinders 1 and 3, and sends the coolant temperature signal to the gauge in the dash.
thanks,
Raf
Update:
Question...
This sensor is for the gauge inside...
There is another sensor for just the fan...
Can I still run my car and the fan turn on, just the gauge won't move...??
I need to get a new sensor, end broke off and I want to run the car without it overheating / damage... Thanks,
Raf
Raf
correct, as long as the sensor for the fan is not broke, it is common for them to break due to the heat, the fan will still work. the two sensors are independent of each other.
