WHATS THE DEAL WITH THE COOLING FAN
Old Aug 4, 2007 | 02:04 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
I have an 86 305 tpi, and living in the great state of Cali.. the summers can get a lil warm.. Normally the car is right in its usual 165 to 215 range (depending on my driving habits that day), but I noticed my coolin fan NEVER comes on. The only time I can get that sucka to activate, is when I plug in the Code Scanner.. All electrical appears to be in good shape, I replaced the fan relay, jus curious about possibly the motor itself for the fan... But that works when the code scanner is hooked up...... HELP ME PLEASE
Old Aug 4, 2007 | 02:47 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: WHATS THE DEAL WITH THE COOLING FAN
check the cooling fan sensor in the passenger sdie head between #6 and#8 spark plugs either the end melted off or the sensor may be bad
Old Aug 4, 2007 | 05:03 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
If your fan switch has 1 wire, you can ground it and the fan should run. Check your connections and for burnt wire. If your sensor is bad, this may be the time to get one that turns on sooner so your car will run a little cooler.
Old Aug 5, 2007 | 06:36 PM
Copchaser's Avatar
thanks...I forgot about that sensor.. I will get on that tomorrow after work and let u know how that turns out... Keep ur fingers crossed
Old Aug 6, 2007 | 02:47 PM
Copchaser's Avatar
well... come to find out... The moron who previously owned this sexy hunk of metal neglected to put antiseize on the bolt for the T-stat housing and well... I BROKE IT... The bolt has officially welded itself to the intake and I drilled to far down and punctured the bottom of the intake... So we are off to go get another base... So while im at it Im going to replace all the vacuum lines and sensors on the intake... Get back to ya soon........
Old Aug 6, 2007 | 03:56 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
86copchaser76, save that intake, it should be repairable for not too much $$$.
Old Aug 6, 2007 | 09:37 PM
Copchaser's Avatar
u think so?? how much u think it would cost... roughly?
Old Aug 6, 2007 | 09:48 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
No idea really, it`s been 40 years since I had a problem like that but I would guess $25-$50 at most and probably at a machine shop if you can`t do it yourself. If the base is aluminum, I`m pretty sure aluminum can be welded. Maybe float the question for Dyno Don or Kevin91 on this site, they would know a lot more than I would.
Old Aug 6, 2007 | 11:13 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
That is a quick and easy fix with a tig welder. Save the intake. Should not cost more then $20 to $40.00 or a 12 pack of beer. Just make sure who ever you have weld it up knows how to weld good.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
