3rd hole in water pump???
Old Aug 4, 2007 | 04:56 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
on the waterpump there is an extra hole on the drivers side on the mounting flange under the bolt holes that actually goes into the pump... what is that for?
Old Aug 4, 2007 | 05:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 3rd hole in water pump???
dont worry about it, its not used, probably for a brackets or something on a different model.
Old Aug 4, 2007 | 06:13 PM
gapimpin's Avatar
Engine: 383 LT1
well i heard it was for a bypass or something in the block but i have a 96 block that its not used on so i sealed it with metal filler... i just wanna make sure it wont mess up my pump.
Old Aug 5, 2007 | 04:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's a bypass hole. Used with the correct gasket, it will seal against the block so there's no need to fill it.
Old Aug 5, 2007 | 06:07 AM
gapimpin's Avatar
Engine: 383 LT1
ehh i figure its just on less spot to worrie about leaks...
also i was wondering if there is a way to test a waterpump with it off the car to make sure all the seals are good?
its a flowkooler pump that was on an old project car and was taken off and has been sitting in a garage for probably 3yrs or so. it spins free but i wanna make sure the seals inside arent gonna leak.
Old Aug 5, 2007 | 11:30 AM
pearl83SS's Avatar
Car: 1983 Monte Carlo SS
Engine: 305 w/ cam
Transmission: TH350
Axle/Gears: 3.42 w/ auburn lsd +moser 28 spline
woops....posted a reply but i answered a diff question lol
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
