Car gets hot and Diesels HELP!!!!
Old Aug 21, 2007 | 11:45 AM
Preluder77's Avatar
Ok I have a 1986 Iroc z 305 with q-jet, 5spd, The car seems to get hot when in traffic or at a idle. It has a new water pump 180 stat, new coolant temp sensor, fans working, Have code 15 for CTS. Timing is good i even tried setting it to about 4 degrees with no difference. Even when the car is running about 180 degrees it will diesel when i shut it off. The car is bone stock with only 59k orginal miles. The car is in great near mint condtion i just need to get this problem fixed. Anyone have any ideas or experiance with this problem ?
Thanks for any help
Old Aug 21, 2007 | 08:30 PM
Preluder77's Avatar
Re: Car gets hot and Diesels HELP!!!!
Any1?
Old Aug 21, 2007 | 09:37 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Try running a few gallons of premium gas when you are close to empty for the dieseling and see if that does anything other than make your wallet smaller. I am just guessing here but I would bet it is heat related. Adjusting the timing or using premium used to be an easy, quick fix for dieseling but with all the sensors etc on these cars, I am not sure. Have you tried doing a search on this site?
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 11, 2015 03:17 PM
86Base
Aug 8, 2015 01:34 PM
