broken thermo housing bolt
Old Sep 9, 2007 | 04:24 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
OK i need to change the thermostat, tried taking off the 2 bolts and snaped the right one off just below the surface of the housing, it loosened some so the thermo stat housing barely lifted off the surface, whut should i get to drill this out, i have drills, i also have a dremel, any help on the bits would be awesome and some mild directions to drill it, and tap it, i need another tap kit the one i have im not sure if it will fit, help :/ got school tommarow first day of college ( and im almost 25 lol) go navy! thanks for help!!!
Rough
Oh and my cars info is <--------------------------------- ova der!~
Old Sep 9, 2007 | 04:42 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
Re: broken thermo housing bolt
that sux same thing happened to me once
#1 get a center punch
#2 make sure you center your drilling VERY IMPORTANT
#3 start with the smallest bit you can DO NOT line up the bottom of the bit (where the swirls stop) with the chuck, it will be a weak point and brake.
#4 lub the bits with wd 40 of something when drilling
#5 be very careful with the tap go 1/2 right then 1/4 back to the left.DO NOT SNAP TAP that what happened to me.
good luck i hope this helps
Old Sep 9, 2007 | 04:50 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Sweet what do you mean by DO NOT line up the bottom of the bit (where the swirls stop) with the chuck, it will be a weak point and brake.
have any idea whut size bits i should pick up ? and what kinda tap set thats not costly?
Old Sep 9, 2007 | 07:31 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
is the rest of the bolt sticking out of the manifold ? you said it broke at top of thermostat housing . if so , your lucky . if enough of the bolt is sticking out of the manifold to get channel locks or vise grips on . wire brush all rust away , soak with wd-40 , pb blaster , good penetrent oil . take your time , tap bolt stud with hammer while soaking with wd40 . go get a cool one come back out . few more taps and wd40 , try channel locks . still no go apply heat [ propne torch ] to manifold bolt area . wd , tapping , heat , channel locks , should do it . LOL
Old Sep 10, 2007 | 01:05 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
wish it was that ez i went out and bought a **** ton of bits, carbide bits are the ****, i managed to get the neck off ground down the stubbs, we tried these square ez outs, they were ****, never buy powerbuilt tools there crap to!!, all they did was break off and i had them jammed in there right, whut crap, i took the other bolt, well tried to and it broke, obviously the idiot who had the car before me over tightended them big time, so im taking the manifold off, gonna take it to a machine shop have them buzz it really quick, if i had the cash id put a aftermarket one on, but baby on the way gotta save that dough :/
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Jeremys87
Jul 14, 2022 09:08 PM
Orr89RocZ
Oct 7, 2015 12:47 PM
