overheating bad???
Old Sep 11, 2007 | 08:28 PM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
overheating bad???
so i have a 95 firebird formula with the lt1 for a daily driver... it has a 160 thermo in it and it stays at about 165 to 175 when crusing down the high way... but when you pull in to mc donalds to get something to eat the thing heats up to almost 250... my electric fan is on all the time so its not that... what else could it be?
Old Sep 11, 2007 | 08:49 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: overheating bad???
Stay away from McDonald`s. You might check out your thermostat, it may be time to replace it and to service your cooling system if you have`nt done so for awhile. You might want to check between the radiator and condensor for blockage, leaves, dead critters etc. Just curious but how do you know your fan is on all the time? Is it losing any coolant, are you having to add any or has it been low? This time of year and as hot as it is, almost 250 is hotter than I want to run but my `88 Iroc with dual fans will run almost 250 when the conditions are right.
Old Sep 11, 2007 | 09:10 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Yeah, check coolant and if it's brown and dirty, flush it. Also squeeze radiator hose to make sure coolant is getting past thermostat. I'm also wondering how you know both fans are on. Double check. Do you see them going. If none of this helps, then yes, you have something blocking the radiator like leaves, dirt, dead animals, etc. (lol)
Old Sep 16, 2007 | 09:40 AM
Car: 85 camaro
Axle/Gears: 342
i know both fans are on casue as soon as you start the car the come on and you can see and hear them.. coolants good never leaks and thermostat is brand new hypertech 160... the car runs nice at 165 170 as long as you keep it moving at like 30 or above.... coolant is nice and green too...
Bubbajones_ya
Jul 6, 2024 08:32 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
