Non AC Box
Old Sep 15, 2007 | 09:42 PM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
Non AC Box
Yes I tried to search but none directly answered my question that I read.
I bought my car, with no center console(aka no controls) and no heater box under the hood.
I replaced my heater core, trying to piece the heater compontets back togehter, these michigan winters can be bad!
Do I just get a Non AC heater box and find some controls in a junkyard and hook the cable up to the door and i got heat?
Old Sep 15, 2007 | 09:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Non AC Box
The entire duct system behind the dash is completely different between A/C and non-A/C cars.
Old Sep 15, 2007 | 10:49 PM
Car: 1986 firebird
Re: Non AC Box
so swapping in this box is a lot more work?I just need Heat, I have no AC stuff on my engine.
Can an AC heater box still fit in my engine bay with headers?
do you have any suggestions on how should I tackle this problem?
Old Sep 15, 2007 | 11:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Non AC Box
It depends how complete a swap you want to do. If you want the car just like a non-AC car, you need to swap the entire dash. If that doesn't matter, you can just put the A/C controls in.
Old Sep 16, 2007 | 12:32 AM
L0tuS's Avatar
Re: Non AC Box
if needed i striped an 83 z28 that had factory A/C delete ill take pics of the heat box and blower box tomorrow. i dont have the controls. iam planing on useing just the blower box to move air around in the car.
Old Sep 16, 2007 | 08:14 AM
Car: 1986 firebird
Re: Non AC Box
So the AC heater box can fit, and I just hook up the AC/Heat controls and thats it?
I just need heat the simplest and easiest way
or did you say, I put a non Ac box in and hook up the controls?
Last edited by Freakazooid52; Sep 16, 2007 at 08:15 AM. Reason: Automerged Doublepost
Old Sep 16, 2007 | 02:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Non AC Box
Either heater box will fit on the engine side of the wiring. I believe the motor wiring between the two is slightly different, but nothing major.
In the interior, the quickest and easiest will be to just put the controls back in for whichever duct system you still have.
Old Sep 16, 2007 | 04:00 PM
Car: 1986 firebird
Re: Non AC Box
Thanks Aperion for you simple answer
Ill begin my search now for a non ac box and some heater controls from an AC car. The wiring will be easy to figure out.
Thanks a lot!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
