Stewart Stage 2 Water Pump
Old Sep 13, 2007 | 10:53 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I just received this water pump from Jegs (great service, btw), and noticed that the shaft turns smoothly, but seems to have more drag than I would have expected. So, I did a search, and found similar comments from other users of the same pump, along with fitment problems such as bolt-hole alignment and bracket interference. I haven't installed the pump yet. Does anyone have some recent experience with this pump's installation and function? Thanks in advance
Bill
Old Sep 13, 2007 | 12:19 PM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Re: Stewart Stage 2 Water Pump
I put this pump on my 10.5 CR 383, love it. I believe Stewart claims (off their website) that it only chews up 4 hp. So it seems to be a very effecient pump. Bolt holes lined up perfectly. However I did have to use a waterpump pulley shim (1/16" IIRC), not a huge deal, they're cheap.
Old Sep 13, 2007 | 01:38 PM
Burnout91's Avatar
Engine: Modded L98
OK, thanks for the reply. Did you buy the shim (if so where), or fab it yourself? Anyone else?
Bill
Old Sep 14, 2007 | 09:34 AM
Car: 1986 Iroc
Engine: Afr 408
I bought the shim, Mr gasket sells them in a pack of 3. I forget the sizes, but I used the middle one, 1/16". It was like $3-5. I got mine through summit. I'm sure jegs has it, and probably autozone or the like. You could easily make one, but for $4, I'll save myself some effort.
Old Sep 14, 2007 | 09:57 AM
Burnout91's Avatar
Engine: Modded L98
Thanks Thomas!
Bill
Old Sep 15, 2007 | 11:25 AM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
I also have that pump. 357 CI 10.5 CR and with the Summit 31x19 Radiator, it works awesome. I'm really impressed by the pump and it is well made. Good piece.
Old Sep 15, 2007 | 12:40 PM
Burnout91's Avatar
Engine: Modded L98
OK, sounds like it should be a good upgrade from stock. I'm hoping it will help the car run a little cooler on hot days.
Bill
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
