Summit "Direct Fit" Alum. Radiators . ..?
Old Oct 9, 2007 | 12:20 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Can I get some recent feedback on these radiators?
Older threads seem to say they were about $190, must've jumped in price.
Still better than what I've read about "Be-Cool".
Is this the same one?
# SUM-380455
http://store.summitracing.com/partde...5&autoview=sku
How is the install? Will my stock fans, a/m tranny cooler and condenser have a hard time all fitting?
Any additional parts needed? Results after completion?
My stocker on the '89 GTA is fine and my temps stay below 200*, but I'm just curious at this point.
Thanks in advance!
Old Oct 9, 2007 | 06:07 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Summit "Direct Fit" Alum. Radiators . ..?
Outatime, I don`t have the Summit direct fit radiator but I know there has been a lot of posts about them on this site this past summer. From what I remember, they do take a minor amount of fabrication to fit, not exactly a direct fit. They are supposed to be made by Northern who has a good reputation. If no one responds to your question, try the "search" at the top of the page and there should be a lot of good info there.
Old Oct 9, 2007 | 06:27 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
i got one this summer and didnt fit sent it back to summit.... Still lookinf for a decent one myself
Old Oct 9, 2007 | 08:33 PM
Car: '89 GTA
loneroad - Bummer, not what I wanted to hear.
jimdutro - Haha, thanks for the search tip, well aware of it.
However, they've changed the function as of late it seems and I have not been able to pull as accurate of results as I used to.
Old Oct 9, 2007 | 08:43 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
I am running one in my gta, I would not call it a direct fit but it is a very nice radiator. I had to hammer the inner subframe rail around were the lower radiator hose goes and comepletely un screw the drain **** so it would clear the stearing box when i installed it. overall I am very please with the radiator, its freakin massive.
Old Oct 19, 2007 | 10:57 AM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
I have a Griffin alluminum radiator they offer it in different sizes it was pretty easy to fit it in but still required some minor modification but i don't remember how much i paid but i think it was a little more then this summit one
Old Oct 19, 2007 | 05:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have the direct fit radiator, though i think i got mine from jegs. I had a single fan and it fit ok, the frame rail needs a little hammering to get clearance around the lower radiator hose connection, its not required, but it keeps things from rubbing, also i had to cut a small piece off the end of the upper plastic radiator support, no biggie, and i think i needed to notch a little of the lower support for the drain to work. Its a good radiator for the price, it keeps my engine good and cool.
Bubbajones_ya
Jul 6, 2024 08:32 PM
69GTOby
Apr 18, 2016 02:34 PM
randy210
Oct 15, 2015 03:43 PM
gta892000
Sep 16, 2015 12:37 AM
roysatikas
Sep 7, 2015 08:08 PM
