AC Delet question
Old Oct 22, 2007 | 09:22 PM
dsw12387's Avatar
AC Delet question
I have one very interesting question to ask. Has anyone on here every tried to do an AC delet, on a serpentine system, and NOT use the AC and Smog pump bracket. If so i would like to see some pictures of how you did it.
Old Oct 22, 2007 | 10:22 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: AC Delet question
Buy march brackets. problem solved
Old Oct 22, 2007 | 10:26 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Aye tis not hard. You can remove anything you want from the serp system. On AC, you have to go over the tensioner instead of under (so that it's pulling away from the alternator. The down from the alterator around the steering pump. Up to and around the waterpump then down around the drivers side of the crankshaft pulley and finally a straight line up to the tensioner. To figure out the length, get a buddy to keep some tension off the tensioner, and use a nylon string to get a rough estimate of length. Then test a few sizes at the auto parts store.
Old Oct 22, 2007 | 10:27 PM
dsw12387's Avatar
Gota have the $$$$ to do that
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Aug 22, 2015 07:49 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
