Air Deflector Height
Old Nov 5, 2007 | 09:47 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Can anyone with a stock height car tell me the "ground clearance" of the stock air deflector? TIA
Old Nov 9, 2007 | 05:31 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Air Deflector Height
Sure, I just crawled under my `88 Iroc and the lower air dam is 4 1/2" from the ground. Much closer than I thought. All original and stock suspension parts too.
Old Nov 9, 2007 | 05:50 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Mines 2 1/2 but Im lowered
Curbs and bump stops a no no.
Later
Old Nov 9, 2007 | 08:00 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Thanks guys...
while you got the measuring tape out, what's the distance from the ground to the lowest point on the bottom of the rocker? Correct me if I'm wrong, but wouldn't you define the bottom of the rocker the same as the bottom of the GFX?
Here's the rules I'm wondering about...
8.5.5. No body component, including the front air dam (spoiler) or lower radiator deflector, shall be lower than 4” measured vertically from the ground.
8.36.1. Minimum ride height is 4.5", to be measured at the lowest point of the rocker panel, but not to include welded seams, floor pan “bumps”, or fasteners.
Mine currently measures 4 3/4" to the bottom of the rocker GFX. 2" to the stock air deflector.
J-money
Jan 4, 2019 09:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
crzycamaro86
Sep 12, 2015 05:51 PM
edoff13
Sep 11, 2015 03:55 AM
FormulasOnly
Sep 6, 2015 10:42 AM
