Relay Pics?
Old Jan 1, 2008 | 10:32 AM
1991TAGTA's Avatar
Car: currently looking for a 1991 TA GTA
Relay Pics?
I have a 1991 Gta and I want to make my fan run at the start of the ignition but I don't know what wire to ground so I took some pics of what I think are the Fan Relays, If they are can someone tell me what wire to ground or what to do to make my fan run at the start?
This are on the Driver side...
This one is on the Passenger side by the A/C...
Old Jan 16, 2008 | 12:20 AM
1991TAGTA's Avatar
Re: Relay Pics?
Bump!
Old Jan 16, 2008 | 12:24 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Re: Relay Pics?
the correct relay is on drivers side. it will have a orange/red/blackwred/green wire. you should have two relays with these color wires just gound the green wire and they will run all the time
Old Jan 16, 2008 | 10:06 AM
1991TAGTA's Avatar
Re: Relay Pics?
Do I ground the wire that comes from the relay or the other one that runs down into the engine compartment?
Old Jan 16, 2008 | 10:23 AM
Engine: 4.0 V-6
Re: Relay Pics?
you can pull the wire off the sensor and ground it or splice a wire right by the relay and then ground it. I believe the wire you want to ground is actually green with a white stripe. Specifically that relay which is the center one in the picture where there are 3 relays. When you do that fan will run all the time when the key is on.
Old Jan 16, 2008 | 01:47 PM
1991TAGTA's Avatar
Re: Relay Pics?
Thank you!
BumpaD82
Feb 26, 2016 02:57 PM
Johnoooooo
Sep 22, 2015 08:55 AM
Gunsbee
Sep 7, 2015 07:10 PM
Glowsock
Sep 6, 2015 06:40 AM
