HEARTER CORE QUESTIONS
Car: 1992 Camaro RS
Engine: 305 TBI
ok so iv been lookin for a heater core for my 92 camaro but every where i go the heater core tubes r bent way differnt than then the old ones so i was wondering from all u guys that have replace ur heater cores befor where did u go to get your cores cause i just cant seem to find the right core
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: HEARTER CORE QUESTIONS
ya, there's been a lot of posts on this (keeping my fingers crossed that this doesn't happen). one guy even heated the tubes and then bent them. did you check at a GM parts place?
Car: 1992 Camaro RS
Engine: 305 TBI
ya i know theres been alot of posts about this but as i look at them no one really says where they got there parts. and no i havent check the gm parts place ill have to look
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Parts I don't want to replace twice I get from Carquest or Napa with success - that's where I got my heater core at, but that was last year.
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
.....You might want to snap a Poloroid and draw up a to size schematic to bring with you to your higher end parts store.
Just another thought; are you sure you've diagnosed correctly? It is leaking and you're not just dealing with a 'no-heat' problem? (I just had to use a little water pressure to blow out a blockage in mine & it's worked great since [even though I keep my cooling system squeeky clean and fresh]) Nitro
Car: 1992 Camaro RS
Engine: 305 TBI
....Is there NOT a part on our F-bodies that dosn't need to be replaced by 150k miles????? I feel for you. If it was summer you could just bypass the thing until you get more time to run the correct part down.....
Nitro
Nitro
Car: 1992 Camaro RS
Engine: 305 TBI
ya but if it was summer i would have time to work with it cause i wouldnt have school so i would have more time plus i have to work out side so it would be better. but this isnt really a time ritical thing cause the car is no longer a daily driver for now im fixin the few problems it has now so when i get my drivers licence it will b a good daily driver again.also my car has over 288,000 miles on it and most of the parts are holdin up well
Car: 1992 Camaro RS
Engine: 305 TBI
ok i give up the onley place i could find that has the part that i know will work is the dealership i just didnt want to go there cause they want 100 somthin as where everywhere else its onley 30 but but im tired of looking i just want to get my car put back togeather and driving again so im gana suck it up and pay the extra 70 somthin bucks.(the onley reson i have a problem with that much more money is im onley 14 and dont have a job so 100 bucks is alot and i really didnt want to spend that much but owell)
Car: 1991 Trans Am
I bought my heater core from Autozone for around $30. The tubes lined up just like the original for me, once I got everything in place. It was a pain getting everything in position, but once I had it it slipped right through the holes in the firewall.
91 rally sport
22
Apr 5, 2016 05:06 PM
