water pump rotation...
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
ok, i am having brainfart issues, and cant remember which way the water pump rotates when you are standing in front of the car and looking at the water pump mounted to the engine...
I replaced the water pump, and wanted to make sure i got the correct pump for my serpentine application,
also, when the rear cover on the serpentine pump is removed, should the impellers have a rotation to the left or right??
Re: water pump rotation...
Serpentine = "reverse" rotation = counter-clockwise
Hard to say how the impeller is designed & shaped. Just pay attention that it will move water OUTWARDS when spun in the correct direction.
Car: 1988 IROC
i thought it was counterclockwise, but is that viewed from the drivers seat or from the front of the car...
im trying to find out for sure because i think i m getting the wrong water pumps, as in non-serpentine pumps..
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
