Coolant Leak Onto Harmonic Balancer?
Old Feb 5, 2008 | 10:16 AM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
After a woe of cooling issues, I have yet another.
The other day I noticed a small leak under the engine, and tried to determine the source. All i could find was where it was dripping onto. The coolant, was leaking on the area behind the belt on the harmonic balancer.
If it isnt the harmonic balancer its the lowest pully to the ground and in the center of the engine.
I am not sure where the water pump is, as some have thought it could be that, was recently replaced, this could not be a cracked block could it? As there was a time where pure water was run, and there were freezing temperatures. I did however drain all the water out before morning came, but who knows...
Thanks in advance for your help!!
Old Feb 5, 2008 | 11:09 AM
SteelTownMadDog's Avatar
Re: Coolant Leak Onto Harmonic Balancer?
It does sound like a water pump leak even though it's been replaced, I've had new pumps fail not long after replacement. Aftermarket parts have poor quality control.
Old Feb 5, 2008 | 11:33 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Definitely sounds like a water pump. If you've got the scratch, pickup a stewart stage II. Or it could be they didn't use liquid teflon on the bolts that hold the waterpump in, or that the gaskets they used were bad. A lot of stuff can cause a leak right there.
Old Feb 5, 2008 | 06:33 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
If you add more h20 then you might try to see where leak is from:
add h20. start car. stop car after a couple minutes. use a dentist mirror from auto parts store ($2 maybe). shine a flashlight and try to see leak using mirror. h20 pump leaks start from a small weep hole from bottom of pump.
Old Feb 5, 2008 | 06:37 PM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
I bet that is where it is coming from.
Old Feb 5, 2008 | 08:09 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Water pump, water pump gaskets, could even be the intake manifold if its running down the front of the block. Could be the thermostate houseing leaking, could be a hose, could be a coolent bypass hose going to the heater core. Best thing to do, is fill it up with water, and try to find a leak. Try to get a hold of a pressure tester and pump it up to 16LBS and try to see where its leaking from.
Old Feb 5, 2008 | 08:32 PM
kcb37's Avatar
Agreed something witht the water pump.
Yes that is the "harmonic balancer"
The pulley on the crank. It helps keep vibration down on the crank so the engine dosen't tear itself apart.
Harmonic balancer is a shade tree/home mechanic term. It is actually call the vibration dampener.
So you know.
Old Feb 6, 2008 | 11:36 AM
Car: 1988 Camaro SC
Engine: 2.8v6
sweet...
::sigh:: sometimes i feel it aint one thing with this car, its another...
Old Feb 6, 2008 | 01:28 PM
AMigs87IROCz's Avatar
Car: 1987 Iroc-z
Engine: Swapped into a 350TPI
Transmission: T-56 Six Speed
Axle/Gears: Moser 12 Bolt 3:42 Gears
The water pump is located in the front of engine, behind belts(obviously) but also check the intake/heads...do you have access to a pressure tester??
Bubbajones_ya
Jul 6, 2024 08:32 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
Magman
Sep 13, 2015 12:14 AM
