whats that thing chill'n on my radiator
Old Feb 7, 2008 | 11:29 AM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
there is a greyish tan thing that is no longer attached to any thing what was it for?
Old Feb 7, 2008 | 11:35 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: whats that thing chill'n on my radiator
maybe part of air management system? I will look under my hood tonight
Old Feb 12, 2008 | 02:37 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Where does the other end of that hose go? Looks kind of like someone did a quickie block off for the heater hose connection coming off the radiator.
Old Feb 12, 2008 | 08:40 PM
scooter500's Avatar
Car: 87 Camaro Z-28
sorry, forgot to get back to you. bet that is part of the air management system, check out these photos
Attached Thumbnails whats that thing chill'n on my radiator-dsc02745.jpg   whats that thing chill'n on my radiator-dsc02743.jpg
Old Feb 12, 2008 | 09:17 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Here I took your pic and outlined some things in paint
Old Feb 12, 2008 | 09:53 PM
scooter500's Avatar
Car: 87 Camaro Z-28
the first shenannaguns is some original insulation on a cooling line
the second thing on the radiator itself looks big in the picture but it really just a sensor that is not used (the radiator was replaced by the previous owner). there's no way that the hose on my car or yours from the air management system could plub there because the hose is too big for that connection & theres a prong for a sensor wire that the picture doesn't show too.
My guess is you air management system wasn't kept when the nice upgrade to a 355 was done. do you have headers?
Old Feb 12, 2008 | 10:16 PM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Think he's probably right. See if the other end of the hose goes to a steel tube that runs along the frame towards the fire wall.
Old Feb 12, 2008 | 10:29 PM
Car: Yes...
Based on the notes you made on that photo — yep, someone did a quick way to block off the heater hose port on your radiator.
The Low Coolant Sensor on the radiator is lower down on the tank. What he circled on your photo is the heater hose connection that's just below the fill neck. Looks like you've got a piece of a rag or something stuffed in there.
Last edited by BretD 88GTA; Feb 12, 2008 at 10:33 PM. Reason: Automerged Doublepost
Old Feb 13, 2008 | 04:14 PM
scooter500's Avatar
Car: 87 Camaro Z-28
I have heater hoses off intake. no rag, looks like could be hard gasket like material. no leaks so good to go
Old Feb 13, 2008 | 06:23 PM
mxcrazed's Avatar
Engine: None
Transmission: none
thanks guys
no to the headers
Old Feb 13, 2008 | 07:20 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
It looks like someone plugged the hose with an old distributor rotor from a small cap hei. Mike
Old Feb 13, 2008 | 07:43 PM
topradman's Avatar
Car: 91 Z28
Hey 83z28, you've got a darn good eye!! I think you're right!!
Old Feb 18, 2008 | 07:44 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
And in scooter 500's pics, that nonsense is the pre 87 AC crap. I ripped all of it out. So much more room. Soon with the LS1 fans. And the serpentine setup.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
Bob88GTA
Aug 18, 2015 03:31 PM
